What about Bob?
Lorena making friends...
holy crap its the shadow demon things from the movie Ghost! they've come after your birfs!
Are the wheels gold/bronze?
It looks awesome. I guess I will have to see it in person.
LOL... that's rock rash.... a whole lot of it... This thing wheels.... HARD. It's not pretty
Full Float - finally got a good day to wrench.
it's under there... that's the best i can say. Alot of buttoning up needs to happen.
The axle is just busy work:
pull the locker out to get the Semifloat axle shafts out... then pull off the third, put the locker back in it while on the bench, pull the FF third, install locked third.
Have to remove about 5 inches off the brake lines, so I'll flare the tip and run with it.
Gotta get into the inner axle seals, they're bad... maybe even buy some cheap rotors and pads... think their bad too...
Yeah, I'm going to drop the tank and either put it in the bed and strap it down VERY well for the time being, or find a free small one to put the OEM pump in.
It needs to be outta there so i can do the exhaust once and for all... Everytime i go wheeling i break the exhaust in it's current location. The exhaust is the reason sliders haven't been built.... kinda a domino effect one thing waiting on another waiting on another... the gas tank is what's holding everything up.
I must of missed the update with the OD Green paint job, looking good :beer:
It was on FB, not on here... jsut rattle canned to make it all the same color. And actually peeling since I had 45 minutes to mask, shoot and get it ready to go to RBD 2010... It'll painted right at some point...
Gotcha, will have to check that out. I think we friended on there. Well it looked good from a distance. How bout sumptin like dis :D
Tell me about it on the buttoning up. I had forgot to tighten all the bolts down on mine when I took it out on a shake down cruise. :doh:
Finally got it complete yesterday... first good day since two weeks to wrench. This swap is time consuming... Especially if you're switching out a locker.... and brake hard lines... messy, just messy... easy just took a whole lot longer than I was thinking.
Now. It needs a rebuild LOL. I'm almost positve the inner seals are shot, but at $18 each... I'm gonna try to hold off.
Sounds like I should have had you put down a deposit for the loan of the FF SST:D
I saw it today and said "doh!"
I can give it back if you need it. I will get into it at somepoint soon.
pulled the gas tank tonight... sized up the crap to go into the new fuel cell.
Don't need it anytime soon, simply seized the opportunity to pick on you some.
