Here's the deal - I wanted a tig since I hate the sparks from a mig or stick when working indoors (basement shop) , not to mention the smoke
. I had used a tig a little bit , so I researched around and bought the Dynasty outright along with a tig runner kit , which was a waste of money (there are far better tig torches , ect out there ) .
So , now I had a tig - had to learn it and spent an insane amount of time reading , watching videos and practicing . In the last 9yrs I've gone from barely being able to run a decent bead on steel to welding some fairly exotic parts , lots of specialty repair jobs and general fab work . I also run the stick side a lot as the Dynasty is the one inverter machine that can run 6010/7010 stick rods decently . I mostly use 7018 for stick work , some 6011 for dirty , farm-like junk that gets dumped here to fix . Lot of steel , tool steel , cast aluminum work here for locals and an occasional crazy-rare part shipped here for repair .
The Dynasty has paid for itself in side jobs alone . I don't earn a regular paycheck welding , except when I get called out to do a pipe casing job for bore work - the local Pipe Fitters don't want that nasty stuff so us Laborer's do it around this area . Welding overhead in a trench box in the mud with water running out of the joint's bottom sucks , but can be done . I've got a ton of metal and slag in my face and doc says it looks interesting on x-rays . Never did like him much .
The reason I push the Dynasty so much over the Synchrowave , the HP Alpha tig , or the Lincoln 185 tig is flexibility . The Dynasty will run on single or 3 phase , can be run on 110V if necessary (it's been tossed into the Cruiser for field repairs running off a generator - 110amps limit) and it has a whole slew of spot timers/slope/frequency/balance controls to use it on nearly anything . The Dynasty series is also flat-out reliable , never heard of anyone truly blowing one up yet . You can score used ones nearly down to a grand and I wouldn't hesitate to buy even a beat up one - Miller has parts and will repair nearly anything .
I seriously want the new Dynasty 280 . Same as above with my 200 , but more power and additional waveforms , plus sd card capability for later upgrade programming . Even if you only stick weld now , hard to beat a well-built inverter for running smooth , steady output even on a generator - no other welder comes close .
Sarge
