anyone know anything about these two welders?
hobart handler 130:
hobart handler 140
I'm sure there's some other things i am missing between the two and the fact that one is new in box from a official supplier vs a used one i found and needs to be shipped to me.... the price is the same to me but the catch is the 140 is used and likely wouldn't be under warranty, and I'm really having a hard time figuring out how much I'm really losing out if i just go with the new one for peace of mind...on the other hand are these welders from hobart pretty robust? any chance i need to worry about a used unit? how much does that extra 10A net you really and couldn't i make up for it with another pass?
Thanks for the help!
hobart handler 130:
- Comfortable 8 ft. (2.4 m) H-9B gun with liner for .023-.035 in (0.6-0.9 mm) wire
- .030 in. (0.9 mm) contact tips
- 8 ft. (2.4 m) work cable with clamp
- Sample spool of .030 in. (0.9 mm) self-shielded flux cored wire
- Spool shaft to accommodate 4 in spools (Optional hub kit available for 8 in spools)
- Power cord with plug
- Hobart Welders - Products - Wire Feed Welders - Handler 130
hobart handler 140
- Comfortable 10 ft. (3 m) H100S2-10 gun
- 10 ft. (3 m) work cable with clamp
- Built-in gas solenoid valve and dual-gauge regulator with gas hose
- Spool hub assembly accommodates 4 or 8 in. spools
- Sample spool of .030 in. (0.8 mm) self-shielding flux-cored wire
- .030 in. (0.8 mm) contact tips
- Quick Select™ drive roll for .024 in. (0.6 mm) or .030/.035 in.
(0.8/0.9 mm) solid wire, and .030/.035 in. (0.8/0.9 mm) flux-cored wire - Hobart Welders - Products - Wire Feed Welders - Handler 140
