Welder extension cord issues...
VT
Website
www.facebook.com
So I took the advice and decided to make my own extension cord instead of buy one. I got the cable and male plug from HD with out any problems. But I cant find the female plug anywhere locally. So I found one from McMaster Carr but its $50 which is pretty rediculous. All the places around here (HD and Grainger) said I should just put a box and a plug on the end but I dont think thats the right thing to do. Is it even safe? So should I just box it? Which box is better metal or plastic? Or a cheaper place to look for the plug?
I put a box with plug in it .
Works fine, most shops I have seen around all do this .
If your going to use it in wet/damp areas use a outdoor box with a waterproof strain relief.
I bolted the box onto my welding cart for a clean install
$50 for a plug that you might run over is just not worth it .
Yeah I thought I was going to find one for $15 or so like the male plug. I dont have a Lowes around here but I figured HD would have it.
Not sure where you are in Vt, but Tractor Supply in N. Clarendon will probably have a plug. x2 on finding one (and everything else for the cord) at Lowes for like $14. 25' of wire with both male and female plugs cost about $60. Home Depot didn't have the plug or the wire.
Got the plug. I found out today that we do have a lowes around here (its pretty new) and sure enough there it was $12. So now I have everything for the cord.
What gauge wire, and what voltage welder? The 220v stuff will be a little harder to find, but still not too hard or too expensive.
Though its 8-3 and 220v
You could have just gone on line with most any welding supply house and purchased the plug.
Cyberweld Power Products
Yeah, cheaper at Lowes anyway.
