This absolutely will work. Personally I strongly dislike rain-X though. The reason I polish windshields is that is the only surefire method to remove it on used vehicles I buy where it has been applied.
I’ll grab some tomorrow.pro will use steel wool grade 0000, this isn’t hard.
I’ll try to get some of this if the steel wool doesn’t work.Have you tried the 100% acetone yet?
Dry, no fluids.Grade 0000 steel wool and your preferred window cleaner.
Didn’t work. I even put it on an orbital sander.pro will use steel wool grade 0000, this isn’t hard.
I think this stuff should be studied as it is obviously the hardest material ever found..
Seriously!! It was from Florida.
Tried vinegar, vinegar/baking soda, acidic toilet cleaner, Lime Away, steel wool 0000 on an orbital sander. Must be nuclear.
Just use it with water?
sudfactory.com
