tons of dealer maintenance but I bought an LX being the most expensive purchase I’ve made because I was tired of tinkering with cars.
You should have bought a corolla
No need to troll.You should have bought a corolla
Not trolling - if you don't want to be bothered with tinkering with cars the Corolla cannot be beat.
Anyways, on our RX350 the water drains from the windshield down the cowl then to each side and exits down thorough the gaps where the side skirt panel/wheel liner clips to the body (right behind each front wheel). This area can get clogged up with dirt / debris over the years (don't ask me how i know). Take the clips off pull the panel down a bit and clear it out.
I believe I’m experiencing the same thing.mine happens when I'm parked on an incline (nose up)
I think on level the car drain system works. But when parked inclined overnight I think the water flows in a way to overwhelm the drains and I get some in the passenger well
The 200, once again asserting it's aristocratic nature on the driver-class. Making peace with the inverted ownership dialectic first feels like oppression, but eventually results in harmony.Park in garage, don’t drive them in the rain or snow.
your username not withstanding, you perfectly described the life of my USDM 200.Park in garage, don’t drive them in the rain or snow.
Then why buy one of the best off road rigs ever made and add off road tires if it's never going off pavement or seeing any slightly adverse conditions?your username not withstanding, you perfectly described the life of my USDM 200.
never seen rain or snow. pampered to starbucks and back.
overly unnecessarily maintained
1) because starbucks drive throughs have curves that sometimes need jumpingThen why buy one of the best off road rigs ever made and add off road tires if it's never going off pavement or seeing any slightly adverse conditions?
Maybe you should come to a meetup (fair weather providing, natch') and some of us pros will show you how to break your recric door, teach the heater T an important lesson with vice grips, top off the cooling water in the 4Lo/CDL actuator housing, and give those KDSS valves their annual ten-rotation workout.1) because starbucks drive throughs have curves that sometimes need jumping
2) i wanted a car where i have to change head gaskets twice a year
3) i wanted a car that leaks
4) i wanted a highlander look alike
sure thingMaybe you should come to a meetup (fair weather providing, natch') and some of us pros will show you how to break your recric door, teach the heater T an important lesson with vice grips, top off the cooling water in the 4Lo/CDL actuator housing, and give those KDSS valves their annual ten-rotation workout.
Good find. IIRC those do have a small black foam gasket on them when new.I found one small source of water leaking. Passenger side rear cover that exposes the jack, looks like the clips that hold the bumper in are allowing water. Crazy…. View attachment 3794036
FYI when I got my rig it had round trim like that across the top of the windshield, and that shape caused a whistle at freeway speeds.I added some weather stripping all around the windshield and cowl today in hopes it’ll solve the front leaking. I noticed that it was actually my driver side floor mat that’s wet and I’m convinced whomever replaced the windshield did a sloppy job because both driver and passenger side trim pieces have gaps and so does the cowl in misc places. This has to be my issue so by adding the weather stripping it sealed all the gaps so fingers crossed it works. It looks OEMish.
The weather stripping totally fixed my issue and totally whistles at highway speeds if I open the windows. Thanks for your help!FYI when I got my rig it had round trim like that across the top of the windshield, and that shape caused a whistle at freeway speeds.
Also continue to monitor closely for water. The way the panel is installed, trim around the outside edge might not seal things.
Always hard to understand what the previous owner may have done, or not done, on a used purchase. These are great trucks, but if the first two owners drove them hard off-road, forged rivers and mudholes, infrequently changed fluids, or any number of aftermarket modifications... you just don't know what you are always buying. These trucks are durable and can look great, but require regular care and feeding and can hide any number of surprises.Update, none of my previous repairs fixed anything. However, I tracked down the cargo area leak. My rear washer fluid line was completely disconnected above the headliner and was pouring fluid in the trunk. Go figure....Still working on the front leak.
