Here's a photo showing one slit, you have to slide under the vehicle from the sides and then look up and outward toward the backside of the rocker panels to see the slits (there's more than one slit but it's often the front slit that gets blocked IME). Already mentioned above, use a thin plastic zip tie (not a screwdriver) and just run it in and out. You can also put some dish soap and warm water into the sunroof drain pan and let it work it's way down through the drain tubes into the rocker panel.
And if you're concerned about rust forming in the rocker panels, once they're dried out, you can spray Cavity Wax inside to bring
the original protection up to spec. There are rubber plugs on the backside of the rocker panel, remove one and spray in
both directions using the wand kit (see link below)
Previous discussion:
Driving during some heavy rain over the last few days, kept hearing a sloshing sound as I pulled to a stop or accelerated from a stop ( if you can call it accelerate). Thought perhaps the doors as the window seals are not good. Checked the drain holes and all doors dry as a bone. It was the drivers side sill pulled the rubber plugs on the bottom of the sill and about a quart of clear water ran out.
Any ideas as to where it comes in from?
