Warn 8k or Tabor 9k winch?
Charlotte, NC
Alright, which winch would you say would be better to get since they're pretty darn close to the same price. The Warn 8k or the Tabor 9k winch?
I wouldn't want either on my 80, too small.
Same price? go with the Warn 8000, that is a proven winch. (abiet too small for an 80)
An 8k winch with a snatch block > 12k winch without.
An 8k winch with two snatch blocks and extra cable = 12k with one snatch block.
More important than the math... What are you mounting this in/to? Assuming an 80... What bumper?
My 12k is admitedly more winch than my bumper is rated to handle (ARB = 10k).
I'm mounting it on an ARB. As for the 12k winch, that's out of my price range. Plus, I don't see myself using it all the time to warrant the price of a 12k. I'm more curious as to what other peoples' experiences have been with the Tabor winch because I don't turn up many results when I do a search.
Be sure to budget in the price of a good snatch block rated to 16,000 lbs for your 8,000 lb model, tree saver, shackles, heavy gloves, etc... Wtihout the related gear, the winch is just a real expensive ornament.
I would not install a winch into my truck that I know will likely require the use of a snatch block.
In your situation I would rather buy a used 12k than a new 8k.
