SOLD VSV Electric plug-don't need anymore
How did you do the plumbing at the switch? Like in the picture or? Thanks
You can plug the vacuum source into one side and while the lever is closed you can check the opposite side port for vacuum. If no vacuum, pull the knob and see which port has vacccum. That would be the port you send to the shut down valve. Play around with each side until you figure out which port is activated by pulling the knob.
H hi ow did you pull the knob off so you can pass this through the sheet metal?
