Voltage
Austria
Hello guys on my bj70 24volt landcruiser there are lights showing up (filter/battery/and diff lock)
i changed the regulator already and then it worked for awhile
now the lights show up again but i measured the voltage on the running car and it was 27volt
13.56 volt on each battery
what could it be?
thx in advanche
☝️ THIS☝️
Whenever nefarious electrical anomalous gremlins continue to lurk about, and the components check out, then I start hunting good grounds. Start with cleaning and re-securing the existing grounds, then if that does not clean things up, then I start adding a ground at various spots until it clears.... then you have found your bad spot. Good luck! :cheers:
So we drove 1 whole week with the car and the batterys are fully charged, that means the alternator is working, pre heat lamp also just show up for 1 second and the battery diff/lock and filter lamp is permanent on, i dont have a clue what it could be?
