Volk Racing TE37XT SL M-Spec Wheels Fitment Help!
Anyone have experience with Volk TE37XT M-spec wheels on our 200‘s and if they would fit?
The size I am looking at is the only one they offer in out bolt pattern.
Link - Volk Racing TE37XT SL M-Spec Wheel 18x9.5 5x150 0mm Pressed Graphite | WVDOX00LPG - https://www.vividracing.com/volk-racing-te37xt-mspec-wheel-18x95-5x150-0mm-pressed-graphite-p-154756232.html
I have used TEs on LC 100 & 200s. feel free to reach out via instagram @rwbmedusa
SEMA 2022 debut for the TE37XTSL wheels
I have the wheels. Honestly not sure what the bore is but I cannot even fit the pass through center caps to make the wheel fit so I’m sure it’s the hub centric version,
These are Falke Wildpeak 295/70/18
I had to make adjustments to the fender liner to push them in more toward the front and also BMC. Sounds like a lot of work but the shop doing it does them a lot and I had my car back the same day. Looks very clean.
I do not notice a big difference in handling with the 0 offset but I was running the stock Heritage wheels with 25mm spider trax spacers prior. Maybe if I went from full stock to 0 offset I’d feel the difference.
Looks so clean! What sliders you running?
Tossed on the 570 today with 275/70/18 and lots of heat massaging and trimming in the front. Still working on how much, but it's doable.
How much massaging is necessary? I've got a Blue 2017 LX just like @xeuxaz and would love to run the same setup. Can you still drop the truck using the Easy Exit function so kiddos can get out and drive around parking lot while truck is lifting to stock position?
AHC in low is fine. Easy exit works great. After some more miles I gave up on heat massaging and just trimmed the front liners. They are replaceable if I change directions later. My LX is on stock suspension with a sensor lift.
TLDR; need to remove front mud flaps, and trim the front liners.
Same, I skipped the massaging and cut. Easy Exit still works fine as long as its raised to N before driving/turning or it'll rub.
