After commuting on the highway in the Kansas City heat the past few weeks, I decided to lay under the truck and inspect things. I noticed the viscous coupler was very hot. The transfer case was quite hot, too. I've never performed this unscientific inspection before, so I have nothing with which I can compare.
I began troubleshooting... All four tires match, have about 6,000 miles, are within 2lbs of tire pressure and have been rotated once. I then put the transfer case in neutral, jacked up a front wheel and it spun with a little resistance. Then I took it to a gravel parking lot and did some lock-to-lock turns when I got off the highway. There was no skipping/hopping, the steering wheel turned fluidly. Then I locked the center diff in 4H and did some more turns. The center diff was clearly locking. Everything seems to be functioning perfectly, but the heat of the VC and TC is new to me.
Should the VC get too hot to touch for longer than two seconds?
