ARCHIVE Victory4x4 GX prototyping
We have the 460 rear window molle panels done. They relocate the third row seat belt clips and also retains the clips for the cargo net.
All bolt in.
It looks like these have the Lights on the sides. That would be cool if they integrate with the Lexus entrance lights. OK I will be ordering these as well. Very nice.
That is innovative looking slider. It looks like it have slots for high lift also👍
Will this design really be as strong as the tubular frame style? Looks interesting, but that is my biggest concern.
To answer questions;
- They include rock lights that can easily be tied into the courtesy lights.
- They do in fact have hi-lift jacking locations.
- Strength is the #1 consideration when we design sliders. These things strong enough to fight off anything you can put your GX into!
Here are a couple more pics of the blitz sliders:
Interesting read. Nice to see the GX getting some support
1. Any diamond pattern or other non-slip on top?
2. Do the lights sit flush or recessed? Worried about them getting destroyed.
3. Is the slider flush against the body or offset a little?
1.) The best option is to use grip tape.
2.) they are recessed behind the slider.
3.) We built a gap between the cut plastic and the slider.
All bolt in.
Really like this. Do you have a price yet for it? I assume it's sold as a set, both left and right?
Also, on your Blitz sliders, will you have any type of through hole for pulling on in case of a tip-over?
  • Like
Reactions: r2m
Looking at the pics of the molle panel, it looks like it would block access to this door if mounted on the driver side. Is that correct?
2030641
What year is that? My 2012 doesn't have that door. Just the door below where the jack goes. I think there's a vent or a speaker in that position. Do you have 3 zone climate and ML sound?
Mine is a 2019...yes to 3-zone climate, no to ML. I keep all my ARB compressor bits and air hose in this compartment, so I don't want to lose access.
The sliders have hi-lift jacking holes, or you could run a strap over the legs.
Thanks! When I'm working again, I think I'll order a couple. One for each side.
Quick question, since I am in the Army (Army reservist) when you say "molle" do you literally mean you can use molle straps if I want to hang any other type of gear that may go on a pack, LBV (load bearing vest), belt or plate vest?
Also is there a ball park weight limit to what can be hung on to it? Maybe 25, 30, 50 lbs? Just a ball park so one doesn't wind up bending the heck out of it bouncing around on a dirt road with it over loaded. The reason is if I get it I'm thinking of bolting my 3,000 Watt inverter onto it and get it off the floor of the back of my rig.
