Vendor for top battery mount fuse block
Fort Collins, CO
I can't find the thread that sells the stainless steel platform that mounts on top of the battery that holds a Blue Sea fuse block and a circuit breaker.
Can anyone enlighten me?
I've searched "electrical mount", "blue sea mount", "blue sea bracket", " "under hood electrical mounting bracket". Ugh. An exhaustive search.
This product has 3 initials ?EA (Something Electrical Mount)
Nope. Neither of those two
Tandem off-road makes two mounts also.. one is the KISS mount and SEMS mount.
This is great. I've been looking for something like this for years. Thanks.
Having seen this item...
What is its purpose again?...beyond just a place to mount electrical stuff (in what appears to be a less than ideal place). That's a whole lotta wire running.
That's the purpose, to not take up valuable real estate in the engine bay. It's taking up just dead air space above your battery. As long as you have a cover over your fuse block and install it properly on the mount, it won't be a problem hitting the underside of the hood. The same wires would be coming from the same fuse block if it were installed in the engine bay somewhere else, but taking up valuable engine bay space and it's a very short run to your Aux battery.
Is that fuse block powering the appliances listed in your signature?
Yes, but currently have a circuit breaker mounted on the engine side of my battery tray. I'd like to mount it on top of the battery. I also have a 6 position Blue Sea that is attached to a custom mount by @NLXTACY See pics #2 and #3 . It's just in the way at times and would rather get it above the battery, more out of the way more often.
