Vehicle missing.....Saga Continues
1Fine40 said:
Take an especially close look at the pipe that exits the intake manifold near the firewall by cylinders 5 & 6....the hose from it should go to the brake booster supplying it with vacuum. Be sure there isn't a leak in that system. A decent leak there can lead to burned valves on # 5 & 6...... past experience taught me that lesson the hard way...
Cheers
I was having trouble figuring out why an engine popped and stumbled and stunk like the showers at Auschwitz. I could pull plug wires #5 and 6 without affecting the crappy idle. Turns out someone had switched the brake booster line with the PCV line. #5 and 6 were sucking air out of the crankcase and not firing. Switch-a-roo and it ran like a top.
I'm going with the points. You said you're missing s screw on the points plate, and you've "polished" the points with emery cloth. You never said you used a dwell meter.
The points gap is just a ballpark, the real tune-up parameter you need to pay attention to is the dwell. Dwell measures the time the points are closed, and I have many times set my gap to the gnat's ass and then checked dwell to find out the dwell is WAYYY off. It makes a huge difference on how it runs if they are way off. Adjust a NEW set of points using the gap to adjust the dwell to within the specified range. Larger gap=lower dwell angle, and vice versa. When the dwell is correct, forget what the gap measurement is.
Also, I've read somewhere that you should'nt file points, don't ask me why. But it's worth the effort to figure out HOW to get a new set of points in there, even if you have to scab in just the new contact arms. You really need to eliminate the points and point gap (dwell) as a problem before you move on to more obscure (and expensive) fixes.
After you have tried evrything and it still don't fix it got back to basics like checking the compression, reclean your connections, etc. I had one engine that blew a head gasket between cylinders.....I could not figure it out until it got worse. Anyhow, I don't think you have this problem but it would not hurt if you have doubts.
