VE pump regulation valve and return line banjo
80 Series 1HD-FT
Anyone played around with different orifice sizes in their fuel return line banjo for the VE injector pump? Just doing some testing with different case pressures and trying to find a source for different sizes orifices
Also further on this, anyone know a source where to buy a 2218017840 valve sub-assy, regulator
Send Josh from JH Hilux a message on Facebook. I saw a post recently where he mentioned about 10 different banjos for VEs.
Anyone know the difference between these three reg valves which is listed by Toyota for the 1HD-FT engine depending on year of producing. 22180-17140 / 22180-17840 / 22180-17881.
This is what the transfer regulator looks like if anyone's interested. It doesn't look like it but this is actually adjustable by changing the depth of the pin in the centre which increases or decrease the preload.
Reduced the preload by 0.2mm and its effect is very noticeable. Have much more control over the timing piston now which enables more flexibility in adjusting light load vs full load timing.
