Hello everyone.
So what I thought was my first day with the FJ finally out of the shop was rained on when, after cruising around for the day, the FJ began to drive jerkily and then went dead and the gas petal went limp. Attempts to start it again failed and I ended up pushing it the rest of the way home.
After resting for a while, it can start up again, but the problem resurfaces after a bit. Checked the spark and everything was fine.
So here is where the issue is and my question to you guys. It just got out of the shop and had a Vintage Air AC system installed. My first thought was that it was a possible vapor lock issue. Dropped it back off at the shop and they're telling me it's not vapor lock, despite the fact that this problem wasn't around before the AC install.
Instead, I'm being told they suspect it's a fuel tank issue because they've found some water in the tank and the tank is possibly corroded. What is everyone's thoughts on the matter? And if it is the tank, should I replace it or just have it cleaned?
Thanks much guys.
Thanks much guys.
