For Sale Vancouver, BC, Canada: 2x 1HZ engines, 2x 2LT-E engines, A343F trans
BiffS
Too many projects... ooh, look. Something shiny.
Vancouver, B.C>
Website
www.mekanix.ca
Building a stockpile of engines and parts, need to clear some room and capital to finish our HD79 truck.
All engines guaranteed running and condition as stated, all were from running vehicles and intended for our own projects, but it's time to focus up a little and downsize.
Priced USD. All can be shipped internationally. First come, first served. Local pickup is ok too.
We only carry new and rebuilt 1HZ engines currently. Please email with how complete you'd like the engine/ accessories/ affixments and for prices
- 2009 HZ engine, 53,000 KM on clock, compression all mid 400s, comes with power steering pump, vacuum pump, alternator and fan, etc. new fuel injection lines, valves adjusted, otherwise original. $4000
- 1993 HZ engine, 78,000 Km on the clock, compression high 400s, but mark 5 head gasket used to permit proper turbo use. Will run perfectly fine non-turbo as well as it is. Top end all rebuilt with OEM parts including head bolts, and timing belt. Comes with G-Turbo style CT26 Turbocharger installed and prepared for turbocharged installation w/ intercooler. HD-T crossover pipe available if you opt to use. $6000 turboed, $5000 normally aspirated. This engine is totally turn key ready; needs no servicing at all to use. New parts alone are worth well over $2500. Comes with AC compressor, Alternator, power steering pump, vacuum pump. Can be stripped down some for reduced pricing. Contact me for details.
- 1992 2LT-E engine: 177,000 KM on clock, Compression all high 400s, no smoke, no leaks, good head. all original, comes with AC compressor, power steering, alternator/ vacuum pump, dressed $3000. We would also ship it as a bare longblock w/ injection pump, manifolds and lines $2000 for those that have a cooked head engine. Both conditions will include a modified fan clutch with high viscosity oil upgrade to ensure longevity.
- A343F w/ t case from 1991 2LTE above. All shifted properly, includes split case style T case, oil drained, filter changed. will ship dry, includes bellhousing for 2LT and torque converter. $900
- A343F no t case, from 1992 2LT-E above, 177,00 Km on clock, all shifted properly; has all new solenoids and filter kit, no fluids. Will ship dry, includes bellhousing and torque converter. As pulled along with engine for 1PZ upgrade/ A442 swap.
Additional accessories available for all of the above including piping, radiators, electronics, etc.
New turbos and intercoolers available separately. Installation available as well.
ships from Mekanix Custom Works New Westminster BC, Canada. Mekanix.ca, Clinton@mekanix.ca
Hey I'm interested in the 1993 HZ-T you have posted here. Do you still have that?
Old post ……. but is the A343F still available with Tcase?
Transmission is, yes. Most of the engines are sold.
