pull the vac line to the distributor and plug the barb on the carb or VSV.
Exit at a point where there is a leak. I guess theoretically if there is a leak at athe manifold or other vacuum line, smoke would exit at that point. Basically just blow smoke into the intake.
Booster is new. Could be distributor; how do I check to see that diaphragm is bad?
Yeah, dont know. Absent checking all the lines, etc, I will probably pull the manifolds off and inspect. Maybe have them machined and put in a new gasket. I find it hard to believe that would be the culprit given they are new (10 yrs old but less than 100 miles on them) and so is the gasket.
