Vacuum on PCV and other valve cover hose? Engine running fine with these off! (1 Viewer)
e9999
Gotta get outta here...
Moderator
US
was playing with the PCV and the other valve cover hose yesterday.
when disconnecting the PCV (it's almost new) I could indeed feel a strong vacuum in the PCV with engine idling. Interestingly, though, disconnecting it did not seem to affect the engine idle much at all. Based on discussions here I was expecting that the engine would struggle. Didn't do that at all...
OTOH, I did not feel any suction at all with the other hose. Is this normal? Is it plugged maybe? I was expecting some vac. IIRC that one is before the butterfly so probably not much vacuum there, but I thought there would be some. And what is this hose for anyway that the PCV doesn't do already?
Tools R Us said:
The "other hose" is a breather, allows clean into the engine.
clean air you mean?
it's connected to the throttle body from what I saw so for sure under vacuum in a normally aspirated engine, though. Unless the space under the valve cover is under even greater vacuum, that hose would not introduce air into the valve area, I would think.
