Vacuum Caps
@ToyotaMatt I knew that you mentioned them before.
I couldn't figure out how to do a search that is both, 'vac' and 'cap,' but, not either, 'vac,' or 'cap.' So I had about two cups of coffee reading about everything from brake boosters to lug nut covers.
how come you did not simply PM me ?
you know your always welcome in my House of TEq Cards 🦄
Oh snap , i almost forgot .............................
if anyone Needs or Want's OEM TOYOTA 3mm Vacuum Hose , i have a few Cases of NOS Vacuum Gauge
Install Kits .
you need to see my photos and the detailed write Up in the Below Link :
OEM TOYOTA
3mm Vacuum Hose Simply IS Killer KOOL , is will outlast the test of time and the Vehicles Normal
Life Cycle of 15-20+ Metric Years as a whole nearly every time , just like the above
Vacuum Caps
I didn't PM you after I came up totally blank when I put you in the search. That, and I like the forum, and I never underestimate the depth of knowledge of the random readers on any given day.
btw, also please take note of my Tweaked & Updated User ID name change ......................:cat:
Below is whats left of the First Sealed Jumbo Parts bag that contained qty x 200 pcs of 04000-11120 kits
and still another to go , also .
I plan on using Surgical Precision to carefully create a wide enough window or door at one corner to remove ALL
the kits at one time , then lay the flat crease free Jumbo bag between 2 pieces of card board or LUAN possibly
then Contact @cruiserdan and inquire about Donating it to the Heritage Museum Out in Salt lake ?
In my Lifetime i have never Seen or heard or a TOYOTA GENUINE PARTS bag this large in Size ?
and of that Vintage as well also late 1970's , its Simply a Jurassic Unicorn to me in Nature 🦄
