- Joined
- Jan 6, 2003
- Threads
- 64
- Messages
- 1,211
I was having a lot of trouble getting my engine running right. It was running ok, but every once in a while when turning off the ignition I would get a kickback as the engine stopped. I assumed it was a timing problem (I had previously timed it with a vacuum gauge) so I broke out the timing light and adjusted it exactly to 7 degrees. However, it ran like crap and had no power when set to spec. After some quick tests, I figured out that the vacuum advance wasn't working properly. Unfortunately, I can't find a replacement assembly anywhere, everyplace sells it with the distributor. Since I eventually plan to upgrade to later model electronic distributor, I didn't want to spend the $300+ to get a replacement, so I decided to try and fix the old one. After all, it's broken anyway I can't really can't screw it up any worse
Here's a pic of the assembly. The hardest part was undoing the roll crimp holding the two halves together. I used a small chisel tipped punch and hammer and just worked my way around. Once you get the hang of it, it goes rather quickly.
