For Sale VA: 60 series OEM gears front & rear 3.73 ring & pinion with carriers
4runner2FJ60
virginia beach
  1. 60 Series
For sale, 60 series ring and pinion. Front set shows little to no wear at all, rear has 230k miles, looks polished on the teeth, one chip on the pinion end. Both ran great with no issues, I re-geared and like the new ratio with my setup. Missing most of the carrier bolts. $300.
EDIT: Top picture is the front set.
Edit: $250 for both sets of gears and SF carriers plus shipping. Front set is like new, rear still runs no problem.
Hi,
I am interested in the front ring and pinion only, I do not need the carrier. Can you confirm that the ring has 37 teeth with the pinion at 10 teeth. Do you have the pinion preload spacing washer as well as shim that should have came out during disassembly and can you send a few pics of the pinion and ring gear faces for the front set only.
Thank you
@Herbou Yes they are 100% OEM FJ60 gears, 37 teeth on the ring and 10 on the pinion. Yes I have the washer and shim you speak of. I just removed the ring from the carrier in my shop. Attached are a few more pics. Please PM me about price and shipping. THANKS
UPDATE: SOLD Front gear set alone with pinion shim and spacer. Still available for a deal is the rear gear set and both SF diffs. Misc parts and pieces.
These have 230k miles and ran with no issues at all.
