- Year
- 2001
- Vehicle Model
- LX470
- Mileage
- 200800
- Color
- Gray
- 2001 LX470, Gray over Gray
- Current 200800, Will increase as this is my daily driver
- Interior Gray Leather in 9/10 condition, Driver seat bottom needs replacement/fixes
- Home made storage drawer setup
- Purchased in March 2021 from 2nd owner
- Lexus website has records until 2015
- 18" Tundra wheels with Falken Wildpeak AT3 tires with ~2k miles on them
- 18" Tundra Spare Wheel with matching Tires
- GROM vLine V2 Bluetooth, Carplay
- WeatherTech Floor Mats front to rear
- New OEM Fog Lights
- Oil & Filter replaced every 5000 miles
- Heater T's, Hoses fore & aft of radiator, Timing belt, Water Pump, Air filters, Spark Plugs etc. replaced at 195K
- LCD Display needs to be replaced, everything functional
- Doug Thorley Headers replaced at 197K
- IronMan Stage 2 Foam Cell Pro 2" Suspension Kit installed, AHC disabled
- Scangauge installed in overhead console
- JDM Rear Wiper Arm & Blade
- Ironman Classic Offroad Front Bumper, Stock bumper pad also included
- MetalTech OPOR Sliders, OEM steps included
- LED strips to light up under and around the truck
- Rear Radio/HAM/CB Antenna Mounts
- Lutz Speedo Fix to account for taller wheels
- Small area of rust on the rear trunk lid above the license plate, easy fix.
- Undercarriage had surface rust. It has been entirely cleaned up.
- Undercarriage Rust proof coating done Fall 2021
- NAV Delete Components to replace the entire audio system - Not yet installed
- Lots of other spares, rubber bushings, CV boot kit, etc.
Custom home built overlanding/camping trailer. The base was a M416. Here are the details of the trailer.
- M416 with a VA Title!
- Dexter 3500# axle.
- 6 lug hubs.
- Ready for ebrakes.
- 3 Hub centric Spidertrax Wheel Spacers.
- 295/70/17 Cooper STT PROs. They are probably are good for another 10-15k miles
- Set of 3 (6 lug) FJ/4Runner wheels.
- Rear Offset angled spare mount.
- Sand blasted bed and frame.
- Black Raptor Liner top to bottom in and out all around. Needs some touch up
- Extended frame with Open end front hitch.
- Lunette receiver for pintle hitch
- Rear hitch
- 7 Point jack pipe mounts.
- 4 stabilizers with socket nuts 19mm.
- Wired For 7 pin.
- Split 2 to 3 CURT brake/tail/turn lights kit for quad braking plus left independent turn signals.
- Lid w/dual gas struts angled specifically for easy open/easy close.
- Lid safety lock hidden ready for padlock.
- Interior LED (2) light strips.
- Lid dedicated 7 pin distribution box.
- Lid interior wired for a 12 Volt fridge w/30amp fused cigarette socket.
- HD Roof rack.
- 360° light pods all around.
- Backup led square pods (low wattage) for factory backup.
- Golddog Kaibab Extended RTT
- RTT annex room with floor kit.
- 8ft awning.
- ARB Room 8x8 ft with floor kit.
- 8 ft x 8 ft ARB mosquito room included.
- 100 Watt Renogy Monocrystaline Solar Panel.
- Wanderer 30 amp solar panel controller.
- Tongue box with USB ports, 120 volt Male/Female ports.
- Dual Batteries with boxes and straps.
- All weather proof/Silicone sealed for leak/water issues.
- Main kill switch.
- Bypass switch for vehicles 2nd battery/alt charge.
- Bypass switch for on board dual battery trailers battery isolation.
- Trailer fuse/terminal distribution block. Hot and neutral!
- Ready for e-brake wiring from the distribution (1wire) point.
- Dual side water tight ammo cans fitted and bolted for storage.
- Dual 20 lb propane tanks with mounts and cover.
- ARB Elements Fridge with custom breathable cover for transport.
- ARB bluetooth on board for remote temperature monitoring.
Price: US$ 33,000 OBRO.
