Saw this on Expedition Portal today and thought it was a cool enough hack to share, particularly if you only have one garage door and two unused buttons:
I don't have a wireless winch remote so I can't test this, but the Warn ones operate on 433.92MHz so they likely will work as Toyota's HomeLink is supposed to support 288-433MHz.
The two caveats they mention are:
Try This Wireless Winch Hack (Hint: It Involves a Garage Door Opener) - Expedition Portal
Did you know that you can program your garage door opener to operate your winch?
expeditionportal.com
- You can't just hold the button down as it'll go into programming mode, so you have to spool, release/stop, spool, release/stop.
- You should really turn off power to your winch when not in use so that an errant garage door opener (or your fingers pressing the wrong button in the dark) doesn't unspool your winch
