ARCHIVE ( UPDATED NEW Product ) The Sands of Time Rewind NOW that GOLD ZINC SEMS #7 Stamped Bolt Heads HERE ! 100% MADE IN JAPAN ( NEW PRODUCT RELEASE )
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
UPDATE :
ALL The Latest JIS HARDWARE JUST ARIVED IS ALL ONLY #7 heads
NO more #4 .....
Chromate Plating: The general name for chromate is also called "colored chromate". Chromate consists of a two-layer coating with electrogalvanization on the base. As a manufacturing method, a chromate film is formed by immersing it in a solution containing hexavalent chromium as the main component over electrogalvanization. The chromate-treated material has an iridescent greenish golden appearance and excellent corrosion resistance.
The Sands of Time have begun to rewind
ALL ONLY #7
Stamped Bolt Heads are Back !
100% MADE IN JAPAN
Please see each separate LINK / THREAD Post for Clearly stated Prices , all the prices differ slightly based on bolt size spec. etc ....
M10 x 1.25 x 20mm J.I.S. SEMS GOLD ZINC PLATED STAMPED #7 HEAD BOLTS OEM MADE IN JAPAN , SOLD in PACKS of 10pcs. Each​
$32.00
M10 x 1.25 x 25mm J.I.S. SEMS GOLD ZINC PLATED STAMPED #7 HEAD BOLTS OEM MADE IN JAPAN , SOLD in PACKS of 10pcs. Each
$34.00
#8 stampes head 10mm x 1.25 x 40mm long
Matt will additional sizes be offered at a later date?
yes indeed
i started out with the most common size specs i could think of to test the waters
what particulars do you need , / want ?
i can special order stuff too if the quanities meet the minimum orders requirements they are not that strict either
  • M6 x 10..........Qty 20
  • M6 x 12..........Qty 35
  • M6 x 16..........Qty 50
  • M6 x 20..........Qty 50
  • M8 x 16,Qty 50
  • M8 x 20,Qty 70
  • M8 x 25,Qty 40
  • M8 x 30,Qty 40
  • M8 x 35,Qty 20
  • M10 x 30 Qty 35
  • M6 Nuts,Qty 60
  • M8 Nuts,Qty 80
  • M10 Nuts Qty 20
  • M6 Washers,Qty 100 Flat & 100 Split Lock
  • M8 Washers,Qty 100 Flat & 100 Split Lock
  • M10 Washers, Qty 50 Flat & 50 Split Lock
  • M8 x 16,Qty 50
  • M8 x 20,Qty 70
  • M8 x 25,Qty 40
  • M8 x 30,Qty 40
  • M8 x 35,Qty 20
  • M10 x 30 Qty 35
  • M6 Nuts,Qty 60
  • M8 Nuts,Qty 80
  • M10 Nuts Qty 20
what type of hex heads do you prefer ?
Not sure I understand
- simple hex
- flanged
- serrated flanged / tigers teeth that bite in
- sems flange / or loose free spinning washer on hex bolt ........
Hey a fellow Coleman nut and drinker from the glass lined tanks of old Latrobe! I need some of that hardware. If you haven't shipped that last order already...
i have displayed only a small portion of my total first order
do u understand the links ?
each one to a differeent size spec etc ...
let me know how i can help
A complete set of the correct/identical to OEM bolts, Made in Japan, for a FZJ80 engine bay (or even the complete vehicle) would be nice to find.
