So, after looking around. I could not find a good write-up on or someone offering a good hidden winch mount for the GX. So this is my solution to hiding my Warn 9.5Ti on a 2004 GX470. I am not sure how other winch's will fit, but you can take the measurements from this winch and apply them to your own. I was surprised on how much room was available behind the bumper cover. My welding skills are not great but the welds have good penetration and I have never had a problem yet (knock on wood). I am not going to go through removing and installing the bumper skin as it is straight forward and only takes about 15 minutes.
Here is the bumper after it has been removed from the vehicle, I did not remove the two extensions that mount to the frame as they will be an integral part of the winch mount.
Here is the GX with the bumper removed. I gently bent the AC lines back towards the bracket and cooler. Just use common since and do not kink the lines.
The bumper is made of what seems to be spring steel of some sort. When I notched the upper channel it sprung apart enough that it would not fit the mounts. I just used a ratchet strap and pulled the posts back into alignment. I then tacked in a 1/4" cold rolled steel plate, keeping the straight edge of the plate to the rear and using the bumper as a guide for the radius of the front edge. Here you will see the bumper with the plate tacked and put back on the mounts for a test fit. You will need some clamps to hold the bottom support up to the 1/4" plate for tacking.
Here is the bumper with the winch set in place to check for clearance. I was amazed at how well it fit.
Here is a shot looking down from the top where there is plenty of room to reach the control lever and plug in the remote.
I will continue is the next post.
