I've got a '92 FJ80 with about 156K miles on it and is my daily driver (when it runs) I've replaced ALL of the parts assoc. with the cooling system (new Rad., new W/P,thermostat,belts,fan clutch, idler pulleys and so on and so on)
I have also replaced ever component in the exhaust sytem except the manifold ( new EGR valve, new converters, crossover pipe, muffler-flowmaster and a new tail pipe) in an attempt to get my truck to pass the emissions test and finally found a guy to get it to "pass".
I have been driving around with a sloppy brake pedal for a few weeks after I rebuilt the front axle to replace the seal between the diff. and the Bir. and while I had it all opened up I thought it would be a good time to replace some of the stuff in the front axle ( new birfields, bearings, seals, calipers, rotors and hoses)
Well I thought that I just needed to bleed the brakes again, did that and still had a sloppy brake pedal...so I replaced the master clynder and then the problem got really weird, I was amazed with how hard the pedal was now, so just thinking that I got a bad unit I pulled it and replaced and had the same issue with the new M/C.
Then I started to think it was my M/C powerbooster, went and got a new and put it on and still had a hard pedal
Well then I had the great idea to take it to a professional shop and let them figure it out, they said the parts that I had put on were ****
and replaced them with Mr. Toyota parts and the problem was still around, so they are looking at my truck to dertimine the cause of the low vacuum.
They've checked the timing, adjusted the valves,replaced all of the vacuum hoses, blown out the vacuum hose connections but still no luck with the vacuum leak.
The motor doesn't leak any oil so the leads my to rule out any type of air being sucked in via PCV and the hoses from the air flow meter are in good shape without any major cracks.
I'n statrting to think that the EGR modulator my have gone south on me and that is where my leak is coming from.
If anybody has ANY ideas I will gladly give them A shot as the guy at the shop is as confused as I am and has put about 13-15 hours into trying to figure out thie problem without much luck, good thing for me he's not charging me to figure it out!!!
Thanks in advance for your time and attention in this matter.
Jess
Jess
