Ultimate Trail Tool Kit (carry on for off road) (3 Viewers)
This is something that I've been meaning to do for some time, put together a secondary tool kit to grab when I'm heading off pavement.
So what I'd like to do is see what the consensus is on what and/or how many tools to carry along when wheeling/overlanding.
I'd like to have a few categories:
Just minimal Metric tools (okay so I can be a little narcissistic and let the Jeeps fend for themselves). I don't need every bloody size metric socket in every depth and point (6/12 point) in every drive size (1/4, 3/8 or 1/2).
So for this section I know we must have:
Hand tools:
  • 3/8" Drive
    • drive ratchet
    • Various adapters: 1/4" to 3/8"; 3/8" to 1/2"; 3/8" to 1/4"; 1/2" to 3/8"
    • 3/8" extensions
      • one short
      • one long
    • 3/8" breaker bar
    • 10mm
    • 12mm
    • 13mm
    • 14mm
    • 17mm
    • 19mm
    • Universal socket: Amazon product ASIN B08DCVR5SB
  • 1/2" Drive
    • breaker bar
    • short extension
    • 12mm
    • 14mm
    • 17mm
    • 19mm
    • 22mm
    • 35mm
    • XXmm for lugs
    • XXmm for wheel hubs
    • XXmm for crank pully
  • Screwdrivers
    • Philips
      • Long/large tip
      • Medium/medium tip
      • Short/medium tip
    • Flat
      • Long/large tip
      • Medium/medium tip
      • Short/medium tip
    • Bit driver with assortment of bits, could replace not having screwdrivers, Torx or Allen set.
  • Wrenches, combo open/box end
  • Allen Wrench set, basic metric sizes
  • Hammer, any or all listed below
    • Claw
    • Ball peen
    • Dead blow
    • Baby/small sledge hammer
  • Pliers
    • Linesman
    • Needle Nose
    • Slip Lock, large
    • Vice Grips
  • Wire cutters
  • Wire Stripper/Crimper
  • Cheater bar, pipe to fit over breaker bar
  • Pry bar
  • Tape measure
  • Reamer (to enlarge hole sizes)
  • Gloves, heavy work type
  • Bottle jack accessories
  • C-Clamp (size ??)
  • Multimeter maybe with thermistor (and extra batteries)
  • Valve stem tool with extra valve stem cores (removing valve stem cores)
  • Drill set, small basic sizes for drilling metal
  • Ratchet straps
  • OBDII code reader, OBDII donggle and an app for your phone will do the same and more.
  • Silicone funnels
  • Sawzall (cordless or corded if you have an inverter) for trail brush
  • Loppers (tree trimming) for trail brush
Power/air tools:
  • Air drill
  • Air angle cutter/grinder and extra wheels
  • Air ratchet (great for tight places when you can't swing a manual ratchet)
  • Air impact wrench (?? maybe not)
  • Air sawzall and blades
  • Air hammer
Replacement Parts (not for the tool bag):
  • Belts
    • Serpentine
    • Accessory
  • Hoses
    • Lower water
    • Upper water
  • Lug nuts??
  • Extra common metric screws and nuts
  • Tire repair kit
  • Fuses, various sizes
  • Wire crimping connections: butt, ring, spade, 3-way
  • 10, 12, 14 gauge electrical wire say ~6'-10' long
  • Valve stem cores and caps
Some necessary materials (not for tool bag):
  • Bailing wire. Not very strong but good for use on items that get hot, e.g. mufflers, things close to the exhaust under the hood, etc.
  • Duct tape, e.g. Gorilla Tape or whatever your favorite is.
  • Electrical tape
  • Cable ties (zip ties), long and strong, reusable if possible
  • WD40 or equal
  • Hose clamps, various sizes
  • Towels, e.g. rags, blue paper shop towels, micro fiber cloths, toilet paper, wet wipes
  • Fast setting JB Weld
  • Permatex Gasket Maker (Gasketing – Gasket Makers - https://www.permatex.com/product-category/gasketing/gasket-makers/?locale=en_us )
  • Small tarp (for working/laying on)
  • Maybe Tyvek bunny suit (jump suit), again for ground work.
  • Starter fluid
  • Ratchet straps
First Aid:
  • Army IFAK (Individual First Aid Kit)
  • Ibuprofen (or other anti-inflammatory)
  • Trauma kit
  • Blood clotting material (may be in a trauma kit)
  • Cynoacrylate (yes, superglue) for closing wounds. You can even get medical grade, but I've always just used what's off the shelf.
  • Neosporin, if it's not already in your kit
  • Band-aids, keep extra, there usually is never enough in a first aid kit.
  • Alcohol wipes
  • Tweezers
  • Scissors, if you don't already have a set on you.
  • Sutures (if you think you have the stomach to do it)
  • Smelling salts (may be in trauma kit)
  • Cotton swabs
Recovery Gear:
Tool list to fill out the factory tools missing from the rear door tray:
20230314_182406-jpg.3272454
Any other categories??
I will try to edit this post as people respond with additional items.
I know this is a very incomplete list, but I just banged this out to get it started.
The biggest question is what are the essential sockets needed on our rigs? I know we don't need to carry an entire Crsftsman 1500 tool Mechanics tool chest. So just how little can we get away with and still be able to self service most issues on the trail, excluding broken axles, cracked heads, blown diff's?
Perhaps a trailer to haul this stuff
Hand tools:
  • 3/8" Drive
    • drive ratchet
    • 3/8" extensions
      • one short
      • one long
    • 3/8" breaker bar
    • 10mm
    • 12mm
    • 13mm
    • 14mm
    • 17mm
    • 19mm
  • 1/2" Drive
    • breaker bar
    • short extension
    • 12mm
    • 14mm
    • 17mm
    • 19mm
    • 22mm
    • 35mm
    • XXmm for lugs
  • Screwdrivers
    • Philips
      • Long/large tip
      • Medium/medium tip
      • Short/medium tip
    • Flat
      • Long/large tip
      • Medium/medium tip
      • Short/medium tip
    • Claw
    • Ball peen
    • Dead blow
  • Pliers
    • Linesman
    • Needle Nose
    • Slip Lock, large
    • Vice Grips
  • Wire cutters
  • Pry bar
  • Tape measure
  • C-Clamp (size ??)
  • Ratchet straps
  • Silicone funnels
Power/air tools:
  • Air drill
  • Air hammer
  • Belts
    • Serpentine
    • Accessory
  • Hoses
    • Lower water
    • Upper water
  • Lug nuts??
  • Tire repair kit
  • Electrical tape
  • WD40 or equal
  • Starter fluid
  • Ratchet straps
First Aid:
  • Trauma kit
  • Alcohol wipes
  • Tweezers
  • Cotton swabs
Recovery Gear:
I'm putting my kit together, and I cross-referenced yours above, which is amazing, with the Overland Outfitters Toyota kit and about 10-20 YouTube videos. A lot of the tools are just moving from my garage tools, so they aren't ideal or new. I'm no mechanic but don't want to be a liability. Thoughts?
3/8" Drive
  • 3/8" Drive x 4.5" Ratchet-Not in your kit
  • 3/8" Drive x 8" Flex Ratchet
  • 3/8" to 1/2" adapter
  • 1/2" to 3/8" adapter
  • 3/8" Universal Joint-Not in your kit
  • 3-pc Drive Extension Set (3",6",10")-Should I leave one of these?
  • 11-pc Drive Hex Bit Socket Set (3-10 mm) Rail -Not in your kit
  • 12-pc Drive Torx Bit Socket Set (T10-T60) Rail-Not in your kit
  • 12-pc Drive Socket Set (8-19mm) 6p Rail
  • 19-pc Drive Deep Socket Set (6-24mm) 6p Rail-I'd think you'd want std and deep sizes.
  • 5/8" Spark Plug Socket-Not in your kit
1/2" Drive
  • 10.5" Ratchet
  • 24" Breaker Bar-Probably too big, but I already had this size
  • Digital Torque Meter-Not in your kit, but probably good for tightening stuff like the lug nuts to spec. It's small, too.
  • Lug Nut Security Socket-Not in your kit, but I'm assuming most have locking lug nuts
  • 1/2" Universal Joint-Not in your kit
  • 17mm Deep Impact Socket (6-point)
  • 19mm Deep Impact Socket (6-point)
  • 21mm Deep Impact Socket (6-point)-Not in your kit. I think this is the size of our lug nuts, no?
  • 22mm Deep Impact Socket (6-point)
  • 24mm Deep Impact Socket (6-point)
  • 35mm Deep Impact Socket (6-point)
Screwdrivers
  • Craftsman 4 in 1 screwdriver-Overkill to have two combo screwdrivers?
  • Stubby Flathead
  • Stubby Phillips
  • Klein 11 in 1 Screwdriver
Wrenches
  • 19-pc. Combination Wrench Set (6-24mm)-Comes in a roll so I might as well have the full kit
  • 8" Adj. Wrench
  • Pipe Wrench-Not in your kit, but good for tie rods? Overkill and heavy?
  • Small Allen Wrench Set
Pliers
  • 9-1/2" Lineman's Pliers
  • 6" Long Nose Pliers
  • 10" Channel Locks
  • 7" Straight Jaw Locking Pliers
  • 6" Long Nose Locking Pliers - I like having both styles
  • 7" Diagonal Cutting Pliers
  • 7" Wire Stripper
  • 6.5" Cutter/Crimper
Misc. Tools
  • 47 oz ball peen/ dead blow- I only picked one, and it's big.
  • 12" Angled Tip Handled Pry Bar- Do I need both?
  • 17" Angled Tip Handled Pry Bar- Do I need both?
  • Tape measure
  • Nitrile Gloves
  • Bottle jack accessory
  • 6" C-Clamp
  • Multimeter
  • OBDII code reader Bluedriver or Innova -I don't have this yet
  • Silicone funnel
  • 9-pc. Solid Punch Set (1/16" - 3/8") -Not in your kit
  • 5/8" Chisel -Not in your kit
  • Telescoping Magnet -Not in your kit
  • Maxxeon MXN Flashlight -Not in your kit
  • Noco GB70 Jump Starter -Not in your kit
  • Utility Knife and Blades -Not in your kit
Misc. Materials & Parts
  • Lug Nuts
  • Wheel Lug Stud-I don't have this yet
  • Fuses-I don't have this yet. Any specifics?
  • Wire Crimping Connections I don't have this yet. Any specifics?
  • Metric Nuts and Bolts and Washers I don't have this yet. Any specifics?
  • Colby Emergency Valve Stem
  • Mopar Gasket Maker
  • ARB Tire Repair Kit-This has additional stems and caps in it.
  • 6'x8' Tarp
  • 10, 12, 14 gauge electrical wire ~6'-10' long -I don't have this yet
  • Safety Glasses-Not in your kit
  • Sharpie-Not in your kit
  • WD40
  • Shop Towels
  • Ratchet straps
  • Hose Clamps -I don't have this yet. Any specifics?
Fasten
  • 16 ga Bailing Wire
  • 1" Gorilla Tape
  • Electrical Tape
  • Rescue Tape -Not in your kit
  • Cable Ties
  • JB Weld
  • JB Weld Steel Stick -Not in your kit
  • Blue Locktite -Not in your kit
  • Gorilla Glue -Not in your kit
3/8" Drive
1/2" Drive
  • 10.5" Ratchet
Screwdrivers
  • Stubby Flathead
  • Stubby Phillips
Wrenches
  • 8" Adj. Wrench
Pliers
  • 10" Channel Locks
  • 7" Wire Stripper
Misc. Tools
  • Tape measure
  • Nitrile Gloves
  • 6" C-Clamp
  • Multimeter
  • Silicone funnel
  • Lug Nuts
  • 6'x8' Tarp
  • WD40
  • Shop Towels
  • Ratchet straps
Fasten
  • 1" Gorilla Tape
  • Electrical Tape
  • Cable Ties
  • JB Weld
Great job putting this together!
  • I probably forgot about ratchets, assuming if you have sockets, well....
  • I would advise against a digital anything for your tools unless you want to keep a maintenance calendar to change batteries. Personally, analog (click, click) for a torque wrench.
  • Most of the tools in my trail bag are either Harbor Freight or Amazon with very high ratings. I don't need Proto, Snap-on, Matco. I just need something to get me out of my situation, and if it breaks, I don't care so long as it gets me home. In short most my tools are expendable. My "good" tools stay at home in the tool chest.
  • I also try to avoid redundancy so I have impact sockets that I'll use for the 1/2" socket set.
  • I forgot about listing a multi bit driver set, but I do have one in my kit with torx, allen and various cross tips and flats.
  • Fuses are cheap and small enough to just keep one of each size which may mean at most a dozen different fuses.
  • One hammer is fine or for me I use the back of my hatchet.
  • Just get on piece of pipe that fits over anything you have for a leverage and double it as a pry bar.
  • For wiring, just have some medium gauge wire, wire strippers and tape. Just enough to get you home to do it right.
  • I don't carry extra nuts and bolts, just because there is such a wide range of fasteners used, even if you did, chances are you won't have the right size when needed.
  • Should have some short of marker (Sharpie) anyways in your center console.
  • YES! Get an OBDII Bluetooth. You can get tire pressures and tire temp's for each tire, see codes, both trans temp's, etc.
  • I don't carry any of the adhesives you've listed since I'd prefer a mechanical fix over a chemical fix.
  • I carry duct tape, good enough.
  • The zip ties (cable ties) I carry are about 12" long and reusable. Just press the tab and they can be removed and used again.
One thing to consider when putting this together, is you don't want to be redundant, don't carry the same size sockets in different drives and depths, adhesives, pick one adhesive that will do it all. Same for tape. Go through your list and consider that, "If I have this, do I still need to carry that?"
On another note, when off roading, you should ALWAYS go with at least one other person if the trail has any difficulty at all, excluding fire and gravel trails.
With two vehicles, if the other person is even remotely competent and carries some gear, you should never have to call Matt's Off Road for recovery.
Tools are a personal thing, and a list for one person may not be the ideal list for another. Yeah there are basic tools EVERYONE should carry all the time, but a person who's a professional mechanic will have a more complete set of tools than myself who just tinkers.
So take that all into consideration, that you don't need every tool and size made.
Again good job on putting this together.
Hope this helps!
Permatex Gasket Maker - I haven't needed it on the GX, but I used it this past weekend to seal a Chevy Trail Boss differential cover that got caught on a rock and deformed enough to lose all the differential oil.
Good list, thank you.
high temp silicone RTV can plug all sorts or leaks, etc.
  • Like
Reactions: r2m
I actually do have an ammo can and keep it in one of the slots on my rear bumper instead of a 5 gal Jerry can. I forget what size ammo it was for but it's about the size of an 5 gal can and I keep some of my recovery gear in there.
50 cal. ammo can
  • Like
Reactions: r2m
NOAA rescue beacon, handheld and mobile HAM + Forest Service and other gov channels radios. (Anyone can transmit on any channel in an emergency.) Winter down mummy bags, xcountry skis except in summer. Gear for hiking out in very bad weather. (We have unpredicted storms.) Chains.
Agreed, I do have a Yaesu FTM-400 AND I also keep a handheld in my glove. This comes in very handy when caravanning and need to stay in touch with when on the road. Also hiking and someone stays at base camp, they can monitor the radio while the hiker, e.g. myself have the handheld.
I also have the mobile wired to my house battery so I don't have to have the ignition on for the radio to be on.
3/8" Drive
1/2" Drive
  • 10.5" Ratchet
Screwdrivers
  • Stubby Flathead
  • Stubby Phillips
Wrenches
  • 8" Adj. Wrench
Pliers
  • 10" Channel Locks
  • 7" Wire Stripper
Misc. Tools
  • Tape measure
  • Nitrile Gloves
  • 6" C-Clamp
  • Multimeter
  • Silicone funnel
  • Lug Nuts
  • 6'x8' Tarp
  • WD40
  • Shop Towels
  • Ratchet straps
Fasten
  • 1" Gorilla Tape
  • Electrical Tape
  • Cable Ties
  • JB Weld
Personally, rather than a meter, I'd go with a 3/8 and 1/2, or at least 1 or the other and an adapter to the size. If i were overlanding, I'd want to torque my lugs to spec with a beefy torque wrench
Most of my tool bag sockets are 3/8" drive, with the exception of the 19, 21, 22, and 35 mm axle nut sockets that are 1/2" drive. I have a 3/8" to 1/2" adapter and a 1/2" M18 mid-torque impact. They'll do in a pinch and I can make things work without having to carry too many different types of sockets/ratchets/etc.
  • Like
Reactions: r2m
