For vhf/uhf I only own the Larsen NMO mounts. I'm not opposed to others, I just have limited experience.
For HF, I only own the 3/8 x 24 stud mount ham sticks (typical CB antenna mount I guess). Again, only due to lack of experience.
My understanding is that there are only two types of mounts for vhf/uhf antennas: The NMO and the UHF (which apparently goes by various other names including the PO, but I'm not sure on this). Among NMO mounts, there is also some variation among manufacturers such that a Larsen NMO coil may not mount properly on a Diamond NMO bracket.
For HF antennas, there are the same two options as above plus the standard CB type ham stick mount (the 3/8" x 24 stud).
Is this correct? What am I missing? I know I've seen 80s with dual antennas mounted on the front ARB bull bar (despite the ground plane issues). And I know these are commonly one HF (usually 11m CB in the states) and one VHF/UHF.
Here is the problem I ran into today when trying to order from HRO. The holes in the ARB front bumper (top mounting tabs) are 3/8" and work fine for the common 11m CB type ham stick antenna. But I'm told there no vhf/uhf antenna that will mount on this tab without enlarging the hole.
So is this correct? If I enlarge the hole, all I can think to use is a 3/4" drill bit and that will put the vehicle side of the hole pretty darn close to the edge of the tab. Also, enlarging the hole will make mounting aux lights in that position more difficult if I decided to do so in the future.
I don't have room on the roof for the optimal drilled hole NMO mount, so I guess the only other option is to ignore the bull bar and just use a hood groove mounting tab and the Larsen NMO I already have.
Thoughts?
Thoughts?
