SOLD TX : NOS FJ45 FJ40 Tailgate Hinge 68905-90305
hyhpe
here
150.00 before shipping
Single “vertical” hole? 68905-60010 (90305) should have two. Curious.
I suppose it would work if the holes are spaced correctly, but it’s one hole short of a SWB/FST tailgate hinge. Just curious wrt that part number.
But then, if the later FJ40’s had drop down tailgates (?) then maybe they went to a single hole to reduce the height of the rear sill. I’ll quit stepping on your sale 😞 , GLWS.
I suppose it would work if the holes are spaced correctly, but it’s one hole short of a SWB/FST tailgate hinge. Just curious wrt that part number.View attachment 2762944
You are not stepping on it. what I post up and what I know about it are two different things. learning as I go. The single hole side of mine has the bend in it where yours does not. Perhaps someone will jump in and explain it to me. @Living in the Past ?
There’s a bend in the two hole version, just not noticeable in that pic. Another curiosity as to their similarity and application. Also the two hole looks to be a bit heavier in gauge.
Maybe Brian has an idea @whitey45 .
3 1/2 inches at its widest point - hinge pin.
3 1/8 =/- flat with two holes
1 7/16 flat with one hole
2 3/16 between the two holes
1 1/8 metal thickness
3/8 holes
I’ll get some measurements in the am when I get back to the shop. Good stuff!
can't say I've seen one like that.
IIRCC
the lpb has 2 holes in a line horizontally in the tailgate
the lp has 2 holes in a line vertically in the tailgate
