Well if anything I need to post a follow up to this posting of the latest outcome.
Received the new carburetor kit #791B yesterday and today did install the new seat and valve for the float and also installed a new float that I decided wouldn't hurt.
Long story short, no change. Set the float 3 times,
1. @ 6mm- 1.1
2. set float @ 7.5-1.1
3. set to float @ 6.5mm -1.1, same.
Fuel bowl sight window when idling,
barely can see the top line of the fuel level when one shakes the truck side to side. This is the same for all the adjustments mentioned.
Under load (high RPM) still the same. Adjusted speed and mixture with vacuum gauge and RPM gauge,runs good just afraid its running rich if the fuel float is high. Will check the plugs in a few days.
Good side it the leak down seems to of halted, dry shaft's, so far.
Changed the oil just incase of fuel contamination from raw fuel dripping into the intake.
Going to inspect the fuel pump to see if it may have internal problems. Also the heat valve seems a bit slow but it opens.
Last but not least get a new carb from Jim or Trollhole.
Non US, two vacuum ports.
Thanks, Merry Xmas
