- Thread starter
- #21
Checked the torque again and the rear two were almost a 3/4 turn until seated to values. Deicide to pull manifold and replace the gasket as I have an extra and do a visual inspection. Was concerned about how much oil/fuel saturated into the center of the gasket if any to where it would dry and crack and end up leaking in time. Was right it was starting to saturate about a 1/4 in on the bottom of gasket. I am hoping that this breach in torque maybe the answer. Will give it a week more of driving and check the plugs.
Question: When did Toyota engines/carbs start to have the built-in gasket materials on the insulator block?
Thanks
Thanks
