I had my flywheel ground and I'm not sure they ground the shoulder down.
I rebuild tranny and transfer and installed a new clutch and pressure plate.
I am not getting much power and thin the clutch is slipping. I've adjusted the clutch fork and pedal.
Question 1: If shoulder of flywheel was not ground down then would that prevent clutch from getting the pressure against the flywheel that it needs?
Second part; just hooked up a timing light and I'm no where close to the indication mark on flywheel. Vehicle runs and I can advance or retard by moving distributer just fine.
Question2: Is there a bolt pattern on flywheel that makes it such that it can only be installed one way? I'm wondering if I have it rotated 90-degrees or something in the way I installed it, which is why the timing mark does not show up.
Ok, I guess I have a third question.....does it matter? Can I somehow make my own timing mark and adjust off that? But how would I know where to make the mark? I am I stupid if I don't pull off flywheel and put in correctly and if so, how will I know where correctly is? (pull off top of engine, piston-1 at top, timing mark on pointer etc etc? UGH!
Any advice would be appreciated.
