Wow lots said here good thread,
I have never looked deep into brake theory just done normal maintenance, but
CharlieS said:
Anything that says That "rotors warping" is just experiencing a transfer of pad material to the rotor is filling you full of pure BS as far as I am concerned. I am not an expert, but I call BS.
Charlie
Agreed.
I have had and measured brake rotor warp on my 80, the rears on my 80 were warped one .030” and the other .035” IIRC (can’t find the thread now), 30 thousands of pad material built up on a rotor would be quite obvious, they were defiantly warped. I measured the new ones and they were only a few thousands. The FSM gives a spec for runout at .006” (0.15 mm (0.0059 in.) front and rear,
The PO had new rotors put on the front (Midas, $700 bill) shortly before I bought it, pads had about half their life left when I changed over to 100 series pads last summer, there was a slight step where the 80 pads did not contact the rotor, I think most of it was rust. I did not turn them just put the pads on partially used rotors, Saw them last week the step is gone, have about 15K on the front pads they looked almost as thick as new. I noticed a must better brake feel with the 100 series pads over 80 series midas pads, they wear well also.
A few months ago I started getting slight warped feel (no where close to the feel the rears had) in the brakes when light pressure is applied. My 80 is mostly highway, I don’t use the brakes often but there are 3 high speed lights on my way to work, if I get caught at any of them there is a 70->0 MPH stop. Maybe this pad transfer phenomenon could explain this light "warped" feeling I currently have.
Guess I should get it up on stands and measure again don’t know when I will get to it.
Are you guys actually doing this pad bedding thing? 10 repetitive heavy breakings with no cool down? Sounds like something a person who makes his living selling brake parts would come up with.
