For a school project I’ve turbocharged a 3B diesel engine, a reliable engine but with a lack of power. I’ll take you through the design to serve as inspiration:
It all started with research and calculations which led to the conclusion that the Garret GT2052 is a perfect match for the 3B. It is a relatively small turbo that delivers boost without turbo lag but with potential for about 1,5 to 2 bar of boost.
After designing various exhaust manifolds we chose for a down-mounted design to keep the exhaust as simple as possible. We chose stainless steel for the exhaust manifold for looks and longevity.
The design for the exhaust manifold, it is kept as simple as possible using standard weld bends with a radius of 76,5 mm and laser cut flanges. Only the weld bends in the middle have to be cut.
If you tack-weld the bends to a steel plate (pointed out by the red arrow), you can clamp the plate in a band saw which makes cutting of the bends a lot easier.
Pipes and weld bends were cut using 3D-printed shells. The shells were designed to fit over the pipe or bend and to have the contours of the cut-out in it. Using these shells we drew the cut-outs and then made the cut-outs using a grinder and a file.
We made a fixture for welding the exhaust manifold as stainless steel warps a lot when welding. We tacked the exhaust manifold using stainless steel wire in a MIGMAG welding machine and it was welded up using a TIG welding machine.
