Hmm.. I see... So if one uses a boost-controller, one can "move" the opening-preassure on the wastegate upwards? I mean can i keep the wastegate as it is and then use a B.-C. to give me more or less boost?
Curious about some plumbing..
There is a nipple on the compressor-housing and on the wastegate (dont know the name.. the part that holds the spring)
These two should just be connected with a hose right?
And if i use a boost-c. it sits between those?
And as i mentioned, what about the hose from the "throttle-body" to the IP What does it do? Is it vacuum from the intake that regulates the fuel-flow?
Can i move it from the intake to somewhere before the turbo on the air-intake.. I'm guessing it will be about the same?
I also wonder what are the best places to take/return water to ensure a good flow that doesnt stop or change direction under any condition..
The oil will go from t-piece behind the oil-pressure swicth
Also the turbo is pretty heavy. Have you guys used any supporting brackets to hold it, or does it only hang from the manifold?
The pop-off
(wich I guess is overkill for my application, but it sounds cool
It goes on the intake-tube right before the intake right? where does the hose, that there is a nipple for on top of it, go?
One more thing.. I keep calling them "hoses" is that correct? or would "line" or "pipe" be more correct.. I'm thinking a pipe is something made from a hard material... like a plumber would use
and a hose is soft made from rubber etc..Maybe tube is a better word? Are hoses for gardeners and firefighters?
I think I have a pretty good english vocabulary for a Nordmann..But there are some "holes" in the technical departement
You guys (especially you Dougal) have been very helpfull....
I think I'll have to ship some delicious Norwegian beer to all corners of the earth when this is "over"...as a token of my apreciation.
