Tapage
Club 4X4 Panamá
How does the bov go in water????
Under water you mean . ?
I don't think it will be agreat idea .. at least not to me. Even with the positive pressure that you got in the sistem.
marting, where are you? Have you cleaned the living room floor?
Rick
does any one know why my turboed 2h uses so much fuel is it because i run no muffler as i was under the inpresion that the turbo will give enough back presure
How much fuel does it use? Does it smoke a lot? Do you know the condition of your injectors? I don't think you really need backpreassure..![]()
hi guy.....just thought some of you guys would like to see the out come of my turbo 2h
Looks good, how much boost are you running?
Hey! That looks like a real good and usable increase in power and tourque... But one thing strikes me, 35kW ?! and 56kW with turbo?
I though it had around 100 hp or 75kW without the turbo
Somebody please explain!
I understand that this has been measured on the wheels, but is 50% of the power lost in the drivetrain?
Will this testresult also vary with wheel-diameter?![]()
Well... I decided to take the water from the drain-plug on the block.. and return it to the rediator-hose.
I have started work !
Got rid of the old exhaust and stripped the front end from it's batteries and radiator..
Drained oil and coolant
Battery-trays have been cleaned and painted.
Cleaned the inner-wells
test-flipped the manifold ends up further back than i expected.
Made holes for IC-tubes
Removed oil-preassure switch, drain-plug and push-rod cover to prepare them for modifications
Oh.. and i attached a picture of my storage-thingy
