Tapage
Club 4X4 Panamá
That's only possible if someone has built a turbo from mis-matched pieces.
If you buy a standard turbo, the compressor is matched to the turbine, if they give you two turbine housing options then each of them will work well with that compressor.
I thought it all depends ..
I've seen plenty of selection on the Turbonetics side, with diferent AR numbers for turbine and compresor side, that go radical from .36 to .68 or more in the compresor side for the same turbo ..
it all depends on your aplication .. thought.
