Hopefully Pinhead or Jim or one of the other carb gurus will see this.
I rebuilt my carb a few months ago and it's been running great. When I did the rebuild, I verified that the vacuum diaphragm was holding and just remounted it. However, recently I did the paperclip test to see if my secondary was opening and determined that it was not.
I checked the following items:
I had
operate the throttle and I verified that the secondary does kick open a bit when the throttle is fully depressed. I had checked this when I reassembled the carb but I never measured the 28*.
I verified that the throttle opens fully and freely when I pull in on the diaphragm rod by hand.
I disconnected the rod from the secondary linkage and did the paperclip test again and the rod still does not move.
I did the suck test again on the vacuum secondary unit and the rod does pull in and holds vacuum (although it takes a pretty good suck to get it in.)
I replaced the diaphragm just for grins and got the same result.
I sprayed carb cleaner into the vacuum port for the vacuum operated secondary and I can see it coming out down onto the secondary throttle plate-so the passages are clear. The restrictor jet on the vacuum secondary is clear and the little gasket that goes around that port is in place.
So based on all of this, I think that I've determined that I do not have enough vacuum to get the secondary to open. I'm basically at sea level and my vacuum runs around 18 at idle. I can think of three things that would help get me get the secondary to open:
Adjust the tang to make the secondary plate kick up more at full throttle. (I'm not sure how sensitive this setting is.)
Put a weaker spring in the Vacuum unit. (This would be easily reversible.) I checked my existing spring and it looks like it would take about 200g to compress it about half way.
Open the restrictor jet some. (I'd rather not be drilling this out unless I need to)
Advice?
I had
Advice?
