Trying to track down a parasitic battery drain and IBS Dual Battery stuff.
Hugh Heifer
What we gonna do today, Brain?
Rome, GA
Website
www.stlca.org
I have been suffering a parasitic draw ever since I arrived in PI. I finally had a day off and got to trying to sort it. My first thought is it has to do with the IBS with the RBM add on.
I am running a Group 31 battery for my main and an Optima Blue for my secondary. The Optima never goes dead so it would seem that whatever is causing the problem is being properly isolated by the IBS system.
We often go about two weeks without driving the truck (2000 100) sometimes maybe three but I would think that if I was not suffering an over 50mA draw that big DieHard Group 31 would be fine for a month or more.
I pulled all the negative cables of and started by testing each ground. (I have one main, one to the body, one to a solenoid for my offroad lights, one for the winch and one that goes to my IBS controller). I found a .05 Amp current on the winch that I found odd. I would not think that would draw current at all when off. But then on the main ground alone with none of the others touching I found a .19 Amp draw. The ground for the IBS controller was not hooked up. I went about trying to isolate the issue by pulling fuses starting with under the hood. There was nothing big until I pulled the AM2 fuse (which I think controls the ignition module) and the amp draw dropped way off. I plugged the fuse back in the amps did not jump. They stayed at .05/.06 (I read .05 or 50 milliamps is the magic number for a car while shut off I have read.)
I hooked everything back up though I unplugged my ScanGauge and I also disconnected the plug at the back of my IBS controlled as I discovered some weird stuff with that.
Here is some of the weird:
When I had unhooked all the ground leads from the main battery and not the aux battery, the IBS showed both batteries good and that they were linked. (The main was unhooked completely.) I found that all the accessories and ignition worked. For some reason, the IBS linked automatically making my second battery my main (or thinking it was both really). The other thing I have noted is that for some reason the IBS begins to beep while driving for 30 minutes or more. I believe this is the "Link Failure Alarm." I have read this is an indication of either overheating of the system or a bad battery that will not charge. But my alternator is charging my batteries fine. There is very little information regarding the "Link Failure Alarm" or link failure at all. (Although I did just find this but have no idea WTF it means:
"The system monitors the charge on both batteries. If the system senses at an applied load (alternator, solar, charger) that there is no charge on the other battery, the link fault alarm with a flashing green LED "linked" is displayed and you hear the beep. If this error occurs, you should immediately check the wiring of power cables (relay, battery terminals, crimp contacts, control relays). Once the errors are corrected, the alarm will automatically reset.")
My wiring is fine.
I have a feeling that the IBS system is failing and causing a parasitic draw while the car is not running and then not acting correctly during regular operation. Unfortunately the site does not have very good instructions or a very good trouble shooting section.
Questions:
1. What all does the AM2 fuse control (yes - I am certain I could rtfm but I have not yet)?
2. On my 2000 100, could having a chipped key nearby cause the ignition circuit to "charge" in anticipation of starting? (This could explain the high amp draw from the ignition circuit as the key was laying on the driver's floor mat.) If I disconnect the ground and then put the meter to it, will this similarly charge the ignition circuit giving me a non-static reading?
3. Do any of you guys have any experience with the IBS system or hear from anyone who has it and has had trouble with it? IBS touts their system to have less than a 1mA draw. I think I may be incurring more than that but did not see it with the meter the way I was testing.
3b. If I unplug my IBS monitor/controller what effect might that have when running or not running? (ie my batteries trying to balance one another.)
4. I think I know the answer to this one - Does the ScanGuage II know to shut off when the car is not running or does it draw some current? I experienced trouble with one of those Bluetooth OBDII senders that stayed on all the time searching for signal even when the car was off.
5. If I have two or three things pulling .03 amps each, this compounds right? So if I had a .05 on the radio and other stock stuff, .05 on the winch and .06 on the IBS monitor unit that would put me a little high at .16 which could be enough I guess to kill a battery in a couple weeks? Thoughts on that?
I am going to keep some notes in here to keep track of what is going on and maybe help in diagnosing this issue.
Since I have been here I had my alternator go bad and I replaced it with an Advance Autoparts special. Cheap, shipped to my door via USPS and lifetime guarantee. Charging has appeared good on the ScanGauge at about 14.2 volts at highway speed (which is rare here). The charging fluctuates between 13 and 14 volts as it should while I accelerate.
On Wednesday (4 days ago) I removed the main battery from my trickle charger. The charger I am using is a 110/240 Battery Tender.
I had been charging the battery for about a week while I was away. The Battery Tenders are supposed to be pretty smart and won't bugger a battery and I have had great luck with them.
I did the testing listed in the original post and then left the IBS head unit (and the ScanGauge) disconnected. I was unsure if having the IBS unit disconnected might cause the the batteries to try to balance or have an otherwise odd effect.
Today (Sunday) I thought I would try some other stuff.
I checked the condition of the Group 31 battery and it was down to about 11.3 volts. Pretty low.
The Aux battery, a blue top, showed 12.1 volts.
So in just days, the Group 31 had discharged to almost nothing.
I reconnected the IBS controller and it verified my findings with the volt meter.
I tested the solenoids on the IBS per the instructions I found on their site and they tested fine per the procedure. Opened and closed like they should.
I disconnected the aux battery.
I disconnected the grounds and tested them together. Hit 50mA. That is what I would expect with a regular car. It jumped all around at first but settled down between 40 and 50. This confuses me since I was at .190 mA on Wednesday before pulling the AM2 fuse.
So the next thing I did was connect the Tender to the Group 31 with it completely disconnected from the truck. I am going to go away for a few days in a monsoon for an infrastructure inspection in the hinterlands. I will be back Wednesday afternoon. I plan to take the truck off charge then, test the volts and write that down. Check the amp draw of all the grounds, and disconnect the batteries again. Then I am headed to New Zealand for two weeks. When I get back I am going to check the charge on the battery and see if is remains the same. If not, I will know that my battery is damaged. (Batteries here suck so I really don't want to have to buy one here and then replace it again in the US when I get home in 8 months but whatever.)
Not sure if your truck has other problems, but I see you have a Diehard group 31. If that's the Platinum AGM, it could causing issues by itself. I've had multiple failures of that battery in multiple applications. You may be better off getting a new one there, even if those available suck.
Diehard 31's are no longer being made due to all of the issues. I went through 3 of them over a 3 year period. I agree, it's most likely your issue.
Worst part is when they replaced my old one they gave me some platinum whatever that is the replacement since they don't make it anymore.....it also seems to suck.
I am thinking you guys are right. A bad battery may also explain the messages being sent by the IBS.
I was out TDY the past four or five days and had the battery on trickle charge with nothing hooked up. I disconnected the charger and watched the voltage drop from 12.5 down to 11.9 volts in about 60 seconds. So it does appear the battery is damaged.
I am going to leave the battery disconnected the next two weeks while I am in New Zealand and see what it looks like when I get back.
I have no idea what to buy here. I don't think there is much in the way of decent deep cycle batteries like this available easily around here. The other issue is that since the Group 31 has multiple studs that I use on the ground side, I will likely have to sort that out too. I really was hoping to make it back to the US without having to replace a battery.
I had no idea folks were having trouble with the Group 31s or that they were discontinued. What are folks going to these days?
For sure bad battery.
After 2 weeks away and the battery unhooked it dropped to 11.4 volts. I tried to desulfate it with my digital charger and I got an error showing a " open cell "
So yeah. Bad Diehard syndrom is likely.
I found a place that sells Optimas and they have a Group 31 Optima in stock. Ef it. I am going to try one.
Thanks for the big 3 comments/suggestions/ideas. Underwelming.
