All- Need some advice. Think my wife may have been too aggressive going over curbs (I’ve Overlanded it, so save the soccer mom comments...
). As a result the steering wheel is 2-3 deg off from center, which is hugely annoying when going down the street...
Put 2020 LC200 Heritage wheels on it a month ago and changed rubber to Grabber ATX at the same time. Took the opportunity to have an alignment done. Hope was that the steering wheel angle would be corrected as part of that. It was not
So question becomes: Is the steering wheel itself splined to the steering column? If so would think I can remove it and correct the clocking by a couple of splines. Does this approach check-out? Don’t want to mess with the alignment on the bottom end. It was corrected significantly and at some expense...
Please Advise and Thanks!
