Trouble with upgrade to Venza oil filter housing (1 Viewer)
San Jose, CA
Did my second oil change on my new-to-me 2011 LX today.
I was excited to install two parts I had queued up: a Fumoto valve, and the Venza oil filter housing (p/n 15620-31060)... as detailed by @bjowett in this post).
All went well until I was all finished with the oil change (including installing the 15620-31060 oil filter housing).
The problem: oil was seeping around and dripping down from the oil filter housing drain plug. I took the drain plug off, and discovered that oil was seeping out from the oil filter housing. Not fast, but steadily dripping.
I can't figure out why this happened. I used the drain valve "disc" that came with the Venza housing. It looks exactly the same as the stock one. Notably, it looks different than the one pictured in Bjowett's post. Also, it doesn't seem to seat well at the bottom of the housing; it wobbles versus seating in securely to the bottom). See this video. I wonder if that is causing the issue.
To resolve the situation, I took the Venza filter out and put the stock one back in (swapping back in the stock tube, of course). All good.
I also included a picture of the oil filter housing drain plug, but I don't think that's the issue.
Thoughts? Suggestions?
Thx!
Grumvee
That's the step that always gets them. :bang:
TWO o-rings come with the filter.
The smaller one goes on the bottom of the filter housing in the grove with bubbles that you pictured.
Wow. Feeling silly.
Thank you.
I read a DIY guide from which I took away that the smaller o-ring was for the plastic tube to drain the oil filter housing.
Tomorrow morning I'll go remove the drain plug and add the o-ring. I'll leave the OEM filter on their for now and next time get the Venza/metal one back on there.
May be common knowledge, but in case not... this Motiv toolset (filter wrench, drain tool, funnel) worked amazingly well and I'd recommend it. Worth the $60 price tag.
Thx all!
Wow. Feeling silly.
Thank you.
Thx all!
I typically pull the old oring off and put it on the drain tool before draining.. keep the new one with the filter nice and clean for reassembly.
But yes the oring is used for both.
