Hello to all. My first post so go easy. I'm in the progress of building up a 99 HZJ75 troopy and I've ran into a few problems.
Number one is that I've got a 1hz out of an 80 series and bolted it up to a h55f gearbox. I dropped the engine and gearbox in as one last week and then I bolted the gearbox cross member onto the chassis. With the engine sitting firmly on its mounts and the gearbox sitting on its mount I cant seem to get the 4 bolts on the rubber gearbox mount to line up. It needs to be moved to the passenger side (Right Hand Drive) about 1cm more. At the moment, looking at the engine from the front it already looks like it is running diagonal enough to make me think that something might be wrong
. The cross member is out of an Fj73 that had the coarse spline h55f gearbox. Is it possible that the older 70 series cross members are slightly different to the HZj75 ones.
The second problem is that the fuel cut solenoid on the engine has 3 wires, where the troopys fuel cut wiring from the wiring loom only offers 2 wires. I have tried different combinations to get the fuel solenoid to click but it won't. Is it possible that I am missing a fuel control relay or that my wiring is faulty somewhere.
If anyone could help me out with these two problems it would be much appreciated
