Questions about fine-tuning my suspension
I have OME 861/862 "low lift" springs, and they have sort of settled down to a point where I'm thinking about adding a 30mm trim packer to the lowest corner and then using OME 10mm and 5mm packers to even things out and try to get rid of the slight sideways lean and "stinkbug" deal.
My question is, with the 20mm(+/-) lift that the OME springs gave me, plus the max of 30mm from the trim packers, will I end up lifting the truck enough that I'll need to worry about caster correction?
