Transmission is going out, what should I do?
Tulsa, OK
Website
www.usedpartswasher.com
Hi Guys,
Man the Transmission on my 2004 with 291,000 miles is failing. What should I do?
Toyota is saying it is on BackOrder.
try posting here in the classifieds:
Ordered one off Ebay. In addition to changing it out, any recommendations? The transmission I found has 145,000 miles. Replace all fluids, anything else? Thanks guys!
5 speed swap
Flip the trans over on your workbench, pull the pan, replace the filter, reseal the pan. After you install and drive it a while, change the fluid again.
I'd personally replace the torque converter. This is the only time you're going to be this close to it.
