Lots of transfer case info and I've looked at a lot of it.
I'm looking for some input & why's/ why not's if a case brakes.
I have a good 66 FJ40 with 3 speed vacuum shift which is I believe the early 3 speed case and a little lower ratio. I also have a a good stock 78 FJ 40 4 speed with the stock split(?) transfer case.
I'm looking at getting a 73 FJ 40 that has been modified. It has a 2F with a 4 speed (probably the 73's?) that has a 4 speed split transfer case - not sure what it came off. Don't know the shape of the t/c on the 73.
If the 73 case is bad is it worth the cost and hassle to adapt the 3 speed case which would include finding the parts to convert from vacuum shift to manual shift. just to get the lower ratio???
Or is it a better bet to just use the good split case 4 speed I also have??
Looking for opinions.
Thanks.
LBM
Thanks.
LBM
