Pulled my transfer case apart. Noticed wear on one side of the idler shaft. Surprised the bearings are actually OK. Checked my spare parts, found another idler shaft and it looks the exact same.
Dealer says not available.
Anyone know of an after market supplier that sells 34MM idler shafts?
I'm tempted to cut a notch for the retainer on the other end of the idler shaft 90 degrees off and install it so the rough part will be on the opposite side of thrust. Also it will be on end of the gear that doesn't carry a load.
