I'm guessing I should be hoping for the PTO cover, in terms of ease to fix?If its not weeping from the PTO cover (L side) and not the output shaft seals, or 4WD switch on the R side, its the case gasket. The Hi/lo shifter is on the top of the case so that wouldn't weep much.
Hopefully the breather plug on top of the case actually breathes, because if it doesn't, the case will get pressurized every time it heats up.
Remove the big skid plate under the car and keep it off until the leak location can be found.
Clean up around the 4WD switch on right side of TFR (wires coming out of it). See if it's weeping from there. In fact clean up the whole thing so you can find the leak. The 4WD switch is easy to remove and reseal the threads if it's weeping. No need to even drain the TFR.
The best stuff I found to clean the TFR is Simple Green Extreme Aircraft and Precision Cleaner (diluted as directed). Don't use the green colored Simple Green. It will wreck the aluminium.
Yea. I saw that in the FSM. Since it was already in place and leaking, I just did it by feel. We'll see..I'm sure that they weren't even close to that...especially the bigger ones.
The transfer case had a leak, which I think I fixed, so I don't know for sure if it is siphoning.was the transfer low?
Hah! I run my interior nude, so there is nothing in the way! Getting to the plate is pretty easy.... I'll check and let you know. I can reach it from the bottom but it is tough to know what I'm doing...Might be easier to do from underneath than to gut the interior to pull the plate.
