Trailer and wheels
Hot Springs AR
I am looking at buying a small adventure type trailer. I am trying to make sure my 1998 100 series 16 inch wheels will mate with new trailer axle hub. Not even sure that these are right terms. What do I need to look for? I am thinking that I need a 5 bolt pattern with 22 mm studs. Does that sound right? Thanks for the help.
Please post up if you find the correct axle. I have not been able to find a 5 on 150. hub
Grogan built an M-416 with matching 100 Series wheels...I think he used adapters. Send him a pm...
I have an 07 adventure trailer Chaser with dexter hubs and electric breaks. The hubs have a jeep bolt pattern of 5 on 4 and a half there are no manufacturers in the U.S making a five on one fifty mm hub. I found a company in denver that is making me wheel spacers. Basicly they are building me a 3 inch spacer that it's not cheap but that how it goes whe you want to go glamping.
https://uswheeladapters.com/Home_Page.php
Here in Australia if you want a trailer with 100 series IFS, Nissan wheels or what ever, thats what a good manufacturer supplies, it's not that hard to have stub axles turned up and the benefit of running the same wheels all round far out weigh the additional cost.
The trailer currently has a six bolt Toyota pattern but also
Previously had a jeep 5 bolt pattern. Which would be easier
To adapt to the 100 series using the above mentioned
Company in Denver?
They can make you whatever you want it probably doesnt matter much to them.
I have found an adaptor that will go from
The the five lug jeep pattern to the 100 series.
Only problem is trailer has six lug pattern on it now
But seller still has the jeep five bolt pattern.
He says he will throw those in with the trailer.
